IPhone 7
Revision as of 20:37, 30 June 2025 by Tiago199988 (talk | contribs) (Added device pictures)
IPhone 7
Manufacturer Apple
Code name
Device type Phone
Soldering
3. Hard
Soldering
3. Hard
Soldering
Teardown
Part replacement
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
2. Medium
Soldering
Cleaning
1. Easy
Soldering
3. Hard
NAND
Soldering4. Specialist
