Galaxy A33 5G No Display
Device Galaxy A33 5G
Affects part(s) Logic Board
Type Soldering, Teardown, BGA
Galaxy A33 screen does not respond at all. Displays no image, but there is a touch input on the entire panel. Replacing the screen does not fix the issue.
  • No display(graphics) on screen
  • Phone boots normally
  • Touchscreen works
  • Charges normally
The problem is due to a missing VDD_LCD_ELAVDD_7P6 signal.
Diode Value
  • Check GR on the connector (you will get a missing GR on a following pin)
    BURNED PIN
  • Check GR on the Capacitor where the area is burned, if GR is ok then proceed to do the jumper like in the following picture
    JUMPER
  • Test the display if it works
  • If everything seems fine cover the jumper with UV oil.
