| Galaxy Note 10 Lite Wi-Fi Grayed Out | |
| Device | |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
Wi-Fi is not working or cannot be enabled. The device fails to detect or connect to wireless networks despite no visible board damage.
- Unable to turn on wifi
- Stuck on faded blue color(depended on theme of the phone)
- No wifi list showing in the settings
- Bluetooth doesn't turn on aswell
There are three main reasons on this specific device the wifi and the bluetooth stops turning on:
- Cold solder under wfi ic:
- Check for any physical damage near the wifi ic
- Check for shorts near the wifi ic
- Remove the wifi ic
- Check diode value under the wifi ic
- If all diode readings are normal, reball and resolder the Wi-Fi IC, then test if the issue is resolved.
- Bad Wifi Ic:
- If there is no change after reballing, replace the Wi-Fi IC with a known-good IC from a donor board
- If still doesn't work try to retrace the OL pads to see for any open lines
- Cpu Problem:
- If you get any open line from CPU side proceed to reball the CPU
- In some cases, all signal lines between the CPU and the Wi-Fi IC may test good, but Wi-Fi functionality will still does not work.
- The solution to this is if you tried all the above is to reball a CPU
- Fixed WiFi:
