IPhone 16 Pro Max Restarting When Opening Camera App
Revision as of 19:38, 27 December 2025 by IamMyron07 (talk | contribs) (→‎Problem description)
Device iPhone 16 Pro, iPhone 16 Pro Max
Affects part(s) Logic Board, CPU
Needs equipment Soldering Iron, Hot Air Station, Soldering Wick, Microscope, Solder Paste
Difficulty ◉◉◉◉ Specialist
iPhone 16 Pro and Max devices experience repeated camera restarts when opening the Camera app.
The root cause is a damaged or missing crystal capacitor located under the CPU.
This fault cannot be resolved by software restore or peripheral replacement. The issue requires component-level repair under the CPU.
  • Camera app causes immediate restart
  • Device reboots when camera initializes
  • Device boots normally but crashes under camera load
  • Issue persists after:
    • iOS restore
    • Camera module replacement
  1. Confirm panic logs
    • Look for kernel panic related to camera or standby
  2. Reproduce issue
    • Open Camera app → immediate reboot
  3. Rule out peripherals
    • Test with known-good camera modules
  4. Board inspection
    • Inspect CPU underside area for missing/damaged capacitors
  1. Remove logic board from device
  2. De-Solder CPU from board
  3. Locate faulty/missing crystal capacitor(s)
  4. Remove damaged capacitor carefully
  5. Clean pads and inspect traces
  6. Install replacement capacitor from donor CPU
  7. Reassemble and test
