IPad Pro 12.9 5th Gen Touch Screen Not Working
Revision as of 19:19, 31 October 2025 by VCCBoardRepairs (talk | contribs) (Added more details for iPad Pro 12.9 Gen 5 No touch)
Device IPad Pro 12.9 5th Gen
Affects part(s) Motherboard
Needs equipment Multimeter, Soldering Iron
Fixing a problem where the iPad turns on but the touch screen does not respond to any input.
  • Non working touch
Fig 1. Check PP15V0_TOUCH_FILT for shorts for No Touch issue
Check for shorts on the capacitors near the two BCM15957A0 touch controllers above the lower display connectors. Often there will be a failed capacitor causing no touch.
Check the following lines for shorts. It could be an IC or a bad capacitor
  • PP15V0_TOUCH_FILT (Fig 1)
  • PP15V0_TOUCH_LDO (Fig 2)
  • PP15V0_TOUCH (Fig 3)
Fig 2. Check PP15V0_TOUCH_LDO for shorts
If a capacitor is shorted, you can just remove it & leave it off. The touch issue should be solved
If an IC is shorted, then you'll need to replace it.
Fig 3. Check PP15V0_TOUCH for shorts
