How To Fix an iPhone 17 Pro That Randomly Restarts
Revision as of 18:19, 22 September 2025 by VCCBoardRepairs (talk | contribs) (iPhone 17 Pro and 17 Pro Max restarting guide)
Device IPhone 17 Pro, IPhone 17 Pro Max
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 17 Pro or iPhone 17 Pro Max to randomly restart every few minutes. For the iPhone 17 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 17 Pro series are:
  • Wireless Charging Flex - The flex that's attached to the back glass. It must be plugged in & not damaged, otherwise it will restart every 3 minutes
  • Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged by water/drops or when someone has replaced the port with a bad/aftermarket one.
    iPhone 15 - FPCs to Inspect for 3 Min Restart
    iPhone Air - Charging Port Flex
To find the panic log on the device, go to Settings-> Privacy-> Analytics & Improvements-> Analytics Data-> Scroll down to the files starting with "panic-full..." & click on the most recent dated file. Then you'll want to scan through the text for keywords that may point you to the cause.
For this model, look for where it says "SMC PANIC - ASSERTION FAILED" ... "Sensor Array" .. "23...."
If you see:
iPhone Air Charge Port - Panic [Fig. 4]
  • 33554432 [0x2000000] - it's the Wireless Charging Flex (Back Glass) [Fig 5]
    • Could be a sandwich issue
iPhone Air - Wireless Charging Flex
iPhone Air Wireless Charging Flex - Panic [Fig. 5]
  • 58720256 [0x3800000] - it's the Charging Port Flex [Fig 4]
    • Make sure the Air Pressure Sensor is plugged in
    • Test with OEM or Premium. Aftermarket parts have a high defect rate
  • Bad or damaged flex
