| How To Fix an iPhone 17 Pro That Randomly Restarts | |
| Device | IPhone 17 Pro, IPhone 17 Pro Max |
| Needs equipment | Screwdrivers, known good parts, spudger |
| Type | Part replacement |
There are many reasons that could cause an iPhone 17 Air to randomly restart every few minutes. For the iPhone 17 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 17 Air series are:
- Wireless Charging Flex - The flex that's attached to the back glass. It must be plugged in & not damaged, otherwise it will restart every 3 minutes
- Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged by water/drops or when someone has replaced the port with a bad/aftermarket one.
iPhone Air - Charging Port Flex
- After a hard drop, the iPhone will restart every 3 minutes.
To find the panic log on the device, go to Settings-> Privacy-> Analytics & Improvements-> Analytics Data-> Scroll down to the files starting with "panic-full..." & click on the most recent dated file. Then you'll want to scan through the text for keywords that may point you to the cause.
For this model, look for where it says "SMC PANIC - ASSERTION FAILED" ... "Sensor Array" .. "23...."
If you see:
- 33554432 [0x2000000] - it's the Wireless Charging Flex (Back Glass) [Fig 5]
- Make sure it's plugged in & the flex is not torn
- Check that there's no liquid damaged, or that it's defective
- Could be a sandwich issue
- 58720256 [0x3800000] - it's the Charging Port Flex [Fig 4]
- Make sure the Air Pressure Sensor is plugged in
- Test with OEM or Premium. Aftermarket parts have a high defect rate
- Bad or damaged flex
