There are many reasons that could cause an iPhone 15 and iPhone 15 Plus to randomly restart every few minutes.
For the iPhone 15 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 15 series are:
Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
Proximity Flex -This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged with a drop & the back glass is breaks. Or when someone has repaired the back glass.
After a back glass repair, the iPhone will restart on its own every few minutes
After a hard drop, the iPhone will restart every 3 minutes.
After a screen repair, the iPhone will bootloop every 3 minutes
The iPhone will reboot randomly when using it.
The iPhone will seem to freeze and restart every 2-5 minutes.
iPhone 15 - FPCs to Inspect for 3 Min Restart
If you see:
0x200000 - it's the Wireless Charging Flex (Back Glass)
Make sure it's plugged in & the flex is not torn
Check that there's no liquid damaged, or that it's defective
Test with OEM or Premium. Aftermarket Flexes have a high defect rate
Diode mode the FPC connectors for any faults
Could be a sandwich issue
0x80000 - it's the Charging Port Flex
iPhone 15 - Charging Port FlexMake sure this flex is plugged in
Make sure the Air Pressure Sensor is plugged in
Check that no flex is torn, liquid damaged, defective
Test with OEM or Premium. Aftermarket parts have a high defect rate
iPhone 15 Air Pressure Sensor
0x100000 - it's the Proximity Flex Cable
0x280000 - it's the Wireless Charging Flex + Charging Port Flex
Make sure both flexes are plugged in
0x380000 - it's the Wireless Charging Flex + Charging Port Flex + Proximity Flex
Make sure all 3 flexes are plugged in
Bad or damaged flex
Low quality aftermarket flex
Other flex cables that are Liquid Damaged
