| IPhone 12 and Above WiFi IC Replacement & Activation | |
| Device | iPhone 12, iPhone 12 Mini, iPhone 12 Pro, iPhone 12 Pro Max, iPhone 13, iPhone 13 Mini, iPhone 13 Pro, iPhone 13 Pro Max, iPhone 14, iPhone 14 Plus, iPhone 14 Pro, iPhone 14 Pro Max, iPhone 15, iPhone 15 Plus, iPhone 15 Pro, iPhone 15 Pro Max, iPhone 16, iPhone 16 Plus, iPhone 16 Pro, iPhone 16 Pro Max |
| Affects part(s) | Main Logic Board, WiFi IC |
| Needs equipment | Soldering iron, Hot Air Station, JC Programmer, JC WiFi IC |
| Type | Microsoldering"Microsoldering" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property. |
On iPhone 12 and newer models, the Wi-Fi IC is paired (bound).
If the Wi-Fi IC fails, replacing it requires unbinding the pairing data from the NAND and activating a new programmable JC Wi-Fi IC using a JC Wi-Fi module for the V1SPRO.
- Wi-Fi toggle is greyed out
- Wi-Fi address shows "N/A" in Settings -> About
- Bluetooth toggle spins endlessly and never enables
- Confirm WiFi is not working in Settings -> About
- Measure surrounding caps/rails near WiFi IC to rule out short
- Check for broken WiFi interposer connections
- Confirm WiFi IC is faulty and needs replacement
- Locate and remove faulty WiFi IC
- Locate and remove the NAND
- Place the NAND in the JC programmer and run Query Code / Unbind
- Reball and re-install the NAND on the iPhone
- Power up the phone and connect it to the JC programmer
- Install a new programmable Wi-Fi IC in the programmer and run Activate Wi-Fi IC
- Once activation is successful, reball the new IC and re-install it on the logic board
- Power up the iPhone and verify that Wi-Fi functions are restored
