| Nintendo Wii SD Card does not read | |
| Device | Nintendo Wii |
| Affects part(s) | |
| Needs equipment | |
| Type | |
- SD Card does not read
- Check FIL43
- Check continuety between pins CD and CD/WP. When the SD card is inserted, it connects these 2 pins to tell the system that an sd card is inserted. If there is no continuity then the sd card slot is broken. Either run a jumper wire between both pins or replace the slot.
